93 polaris 350l won't start
Hi I'm new to the site I have a93 polaris trail boss 350l I rebuilt the top end and I had it start one time since then but when it started it was in reverse we shut it off quick pit it in neutral and can't get it to stat again is there some kind of safty switch were it will only start in neutral
Pull the black wire from the reverse limiter module and see if it helps. When faulty they can die when you put it in gear or won't start in gear. You will then have full power in reverse without having to push the over ride button. Item #34 is the limiter under the tank cover down from the headlight. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
whitty
67
02-24-2021 02:52 PM
