ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris Ask an Expert! In fond memory of Old Polaris Tech. (https://atvconnection.com/forums/polaris-ask-expert-fond-memory-old-polaris-tech/)
-   -   07 Sportsman 500 X2 EFI won't fire... (https://atvconnection.com/forums/polaris-ask-expert-fond-memory-old-polaris-tech/372633-07-sportsman-500-x2-efi-wont-fire.html)
OldNBroken Jul 2, 2017 06:15 PM
Very good site here and very informative, thanks.
ATV has 125 hrs on it and always run great. Daughter was riding it the other day and it just died. Not sputtered and died, just died. Has not fired up since. It will run while holding a soaked rag at air intake and idles fine. As soon as you hit the throttle it dies again and take the rag away and it dies once the fumes are gone.
Have done the obvious and read everything I can on here to edumacate myself. I'm not a mechanic but do have a lot of common sense and would love to try a few things to fix it before buckling under and taking it to the dealer please.
I see all this stuff about the sensors and harnesses and think I should replace them but cannot tell exactly which ones I want to replace and how you replace them. Do you just splice them in somewhere where they join the main cluster? and which sensors and where to purchase them?
Diagnostic codes 22,41,45 and 47
New plug and yes, it's got good spark.
Always use premium fuel and, yes, it did and does have fuel. Pump does buzz when you turn the ignition on, as well as the clicking at the throttle body. Don't have an adapter to check fuel pressure yet but when you remove the quick connect from the fuel rail fuel pours out.
At a standstill here and really hate to give in to the dealership just yet. Am I on the right track? Any help? Preferably some simple idiotic thing I'm overlooking? :)
OldNBroken Jul 2, 2017 11:29 PM
Well, figured it out finally and it was odd.
Finally was able to put the pressure gauge on the fuel pump and got nothing. Seems odd since it primes just fine every time you turn the key. Took out the screws to remove the fuel pump figuring had to replace it and as I'm taking it out saw the pickup tube going out the top slipped out of the clamp holding it into the hose splice to the fuel pump. Pushed it back together, slid the pump back in, turned on the key and bam, 40 psi. So this whole time the pump was working fine, it was just pumping a fountain inside the fuel tank.
Guess I should get another clamp to hold that hose on and hope I can get this thing put back together without too many leftover parts.
old polaris tech Jul 3, 2017 04:40 AM
Strange things even when you think you seen everything that can possibly happen,something like this comes along.Yes I think a new clamp would be in order. Glad you were able to solve your problem as that's the first one I've heard about doing that,but we all learn something new every day.
© 2026 MH Sub I, LLC dba Internet Brands
