Polaris Hawkeye no display and won't crank (but headlights work)
I've got an 07 Polaris Hawkeye that won't start after sitting a few months. It was running fine when I parked it. It has low miles/hours. I thought I just had a dead battery that would not hold a charge so replaced that. Now with the new freshly charged battery the lcd display will not come on and when you turn the key it does not turn over, no buzz, nothing. The headlights WILL come on. The winch does not operate. I made sure the engine kill switch is in the right position. Its in neutral. I checked the 2 15 amp fuses I found under the front cover and they are ok. I can't find any other fuses.
I was hoping someone here can give me suggestions on what to try next or what the problem might be. I would just take it back to my dealer but that's going to be a huge PITA. It's parked at the bottom of a big hill behind my house and getting it pushed up the hill and then up ramps in to the back of my truck is going to be fun...
Thanks for any help.
Mark
Mark
I'll look again when I get home tonight. The housing that had the two 15 amps had a third fuse in it but it appeared to be a spare since it didn't really have any metal contacts that it locked in to. It was just floating in a space between the other two. It was near the battery. I'll look for another in-line fuse. Thanks
Hankey Pankey
26
10-18-2020 03:50 PM
