TPS sensor adjustment on a 2007 Sportsman 800
Welcome to the forum! If the tps sensor bolt is loose then just tighten,try not to move the sensor! If adjustment is needed(not running right) only a dealer supplied harness that sets it to factory specs is needed. It comes with the harness,regulator,connection for 9 volt battery to be used with a volt meter. I'm not sure if SPX tools offers this or not? You can order this through a dealer,just depends if you will need it again?? OPT PS. Sorry about the earlier post,I was thinking the speedo sensor bolt was what you said was loose!
bzdok1234
30
02-23-2016 01:55 PM
