1987 250trail boss oil pump???
Always premix the first tank of gas 50-1 ratio to help break in! Jut hold the oil pump lever up all the way up at idle,it will be as if the engine is running wide open and the oil pump will be pumping faster! I always replaced the small oil line so I could see it start pumping toward the cylinder(after I bled the 10 mm bolt for any air on the oil pump) Plus it won't take long to reach the cylinder and start smoking a little extra because of the premix that is already in the tank as a protective measure!!.NO dry starts! Just run it awhile(the premixed gas in the tank will protect it) Then kill the atv,remove the line at the cylinder and if its wet on the end ,then the pump is working. OPT
exmotocrosser
09-13-2019 06:12 AM
jrooker6
04-23-2016 07:36 PM
BYC
09-25-2015 02:10 PM
Sw00p
09-24-2015 02:50 PM
