01 trailblazer ?
Swing arm doesn't have to be removed to pull the transmission. You may have to loosen the swing arm bolts a little if I remember correctly "IF" they protrude into the transmission case.(I don't think they do) Also can't remember if this model has the combo drain/transmission support bolt. If it does,the lock nut had to be loosen and the bolt turned in to be able get the drain plug out,then to get the transmission out. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
OPT
