screw missing from strut, leaked fluid?
hi guys i noticed this screw missing from the left strut on my 96 scrambler. and judging from the mess of the area i assume that whatever fluid was in there drained out. my question is, can i just put some lube in there and put in a new bolt. and if so what kind of lube. thanks for any insight
I'd go from front to back on this machine and change the trans fluid( Polaris Agl) counter balancer (Holds 75 ccs of 30wt or 10w30 oil) front hubs (Polaris Demand Drive fluid ONLY) and adjust and lube all the chains.Plus there are numerous grease fittings. Plus sounds like you need to replace the strut cartridges if both sides are leaking(best to change in pairs anyway) You can either go stock,plus there are several after market strut cartridges are available. Cycle Parts Warehouse along with Ebay are a good source of parts.
