Fuel pump- 2008 sportsman 500 ho efi
Try Autozone, O'reilly.Airtex Master/Fuel Pump (E8197H) | AutoZone.com
They should be able to match it up.
Probably would as the replacement fuel pump kit from Polaris (2204308 about $280 at Cheap Cycle Parts!!) http://www.cheapcycleparts.com/products/776207 shows to be used in the 500 and 800. You should be able to get an Airtex complete pump for way less.
Probably would as the replacement fuel pump kit from Polaris (2204308 about $280 at Cheap Cycle Parts!!) 2204308 - KIT-FUEL PUMP SPM 500/800 - Polaris OEM Parts - Cheap Cycle Parts shows to be used in the 500 and 800. You should be able to get an Airtex complete pump for way less.
These are just examples. Take your pump out and have em match it up. The two wire electrical connector might be different,but you could splice yours in. This is the one that I've seen in several posts as the pump repair kit that some have used. Price was about $79 http://www.autozone.com/autozone/par...entifier=21930
Plus here's a link for Napa fuel pump kits that some have posted about using.http://www.napaonline.com/Catalog/Ca...118_0210119473
bzdok1234
30
02-23-2016 01:55 PM
micheleLeigh
07-12-2015 02:50 AM
