polaris 325 trail boss
I have a 325 polaris its a 2000 model trail boss 4 stroke I bought this quad used it ran good for a test ride of about 2 minutes so I purchased it now that I got it home once it runs for about 10 minutes and warms up it sputters while throttling but idles fine so I cleaned the carb had some dirt in the bowl put new gas in it stills runs fine at idle but warms up and sputters when throttle anyone have a clue what is wronge with it maybe coil breaking down? im lost please help
Try a carb kit instead of just cleaning a carb. Several parts that can have a lot of wear that you can't just clean and get by with,such as the needle and seat,slide needle,etc.If after the carb is correct and you still have problems move on to the electrical checks. Here's a 5 buck 2002 manual that has the elec schematic and tests and basically the same as your 2000 model.2002 Polaris Trail Boss 325 Service Manual PDF Download Plus don't over look the obvious such as the air filter,plug,etc.
Had that same model. Wouldn't win any races or beauty contests, but it always ran and that's what I liked most about it.
Get the download OPT posted. A manual is a must have for any machine.
Follow OPT's advice, if anyone knows about these machines, it would be him.
And welcome to the forums.
I appreciate the input I will try a carb kit but still dont see how it can run fine for 5 to 10 minutes the sputter under throttling seems it would be something breaking down electrical but thats why I ased for advice because Ive never seen this before
