Running rough
Running rough
My 03 600 idles like it misses every other time or something but when you give a little throttle in neutral it clears up, but in gear it kinda sputters at low speeds. It drives okay but sometimes it's like it can't get gas especially going up hill and the more you give it the worse it gets. After it clears up again at about a medium speed when you give it and more than half throttle it bogs down and won't run over 40mph.. I do have the air filter off but could that really be causing all this or should I be looking for a new carb kit?
Hopefully putting the air filter on and finding a cracked manifold will be your problem. But if it has the older ignition system, I would be willing to bet that is your problem. Your symptoms seem to be identical to mine and I had to replace the ignition system. Good Luck. the replacement isn't super hard but unfortunately the kit is expensive..
Sorry it's been so long, but I put a filter on and it cleared up alot more than I thought it would. I can run it wide open like a scalded ape but it idles like crap or when you're riding a constant speed on a trail it misses alot. Acts like it's running a little rich because I can smell it in the exhaust and it's burning thru gas like crazy
While you're saving up for the kit,if you still keep riding this machine please don't ride alone! Have a riding buddy just in case it decides to die on you and you have to have it towed back.. It's happened to others before and some weren't too thrilled about it especially when they happened to be way out in the boonies somewhere.
With the history this ignition system has on erratic idling,hard starting,excessive gas use,people smelling gas fumes,dying and leaving people stranded,this is the major problem! You can clean carbs,install new needle and seats,etc and probably wouldn't help,same as I've done in the past.These ignitions all fail sooner or later. Plus all you have to do is google "Sportsman 600/700 ignition problems" and see what all shows up.. BUT don't fall for the RM ignition kits out there that are cheaper than the Kokusan kits as they use the existing Ducati lighting coil as a source for the ignition and this coil can go out also! I've had it happen. Then you're out of luck and have to find another used Ducati stator as they are NLA from Polaris! Just do it right and get the Kokusan kit..
hunter56
03-11-2016 02:43 PM
