05 sportsman 500 HO Charging Issue
Ive been searching and seem to find the same answers all the time which dont relate to my problem but are somewhat related to the ecm issues. I have a replaced ecm (surepower) its older! But anyhow, my problem is I charged battery to 12.8v, everything works fine on dash, has new stator but I find the battery does not go up in voltage to 13-14.6v as required when running at 3000-4000rpm. The meter does not spike in voltage, the voltage drops a bit when i turn lights or winch etc on(obviously) so my question is if anyone has had or knows if the ecm would cause this symptom?
Load test the battery to make sure it's in good shape,then get another ecm. Don't get a used one or you're asking for more of the same.2004-2006 POLARIS Sportsman 450 500 Scrambler OEM Surepower ECM PDM 2203348 | eBay
Thanks for the quick reply, I kinda figured it was the ecm as this seems to be these machines weak spot. I'm new to polaris as I'm a Honda guy but seems there's enough info and guys like you who know these units! I ordered one up so hopefully have it next week and see where it goes from there!
I've replaced them from under charging,over charging,fans wouldn't kick on,fans wouldn't kick off along with some that wouldn't send power to the electronics,dash,switches,etc. Too many functions that the ecm controls and any one of sections can go out or multiple sections at once. Just to rule out the new stator charging coil,you can trace the yellows from the stator leading to the ecm module.There should be some resistance between each yellow and no yellow should short to ground.
