1998 Sportsman 500
The bigger bulbous cover(5433540) would work,but you have to make an adaption for your smaller exhaust duct and sleeve as the cover was designed for a larger duct. The updated replacement cover for your model that was built stronger,but still had the same smaller shape and fit the existing duct is #5433542. This cover is expensive on ebay as well as the 5433540. I'd keep an eye out for a good used one in either part #if you don't want to spring for a new one.
Sounds good, thanks! I will keep an eye out. I had found the 5433540 both inner and outer cover for a decent price used but wanted to confirm it would work. May look for the 5433542.
Here is a pic of the new ride along with some info.
1998 Sportsman 500
Purchase price: $500
Needed when I got it:
Clutch work, clutch cover, air box, front gear box/differential, front axles and prop shaft.
Ordered all the parts except clutch cover and air box which I am still on the hunt for.
1998 Sportsman 500
