2012 sportsman 500HO running rich??
Old 05-17-2017, 04:54 AM
peter s's Avatar
Default 2012 sportsman 500HO running rich??
had this quad 2 years, problem just started this weekend. starts and idles fine, will allow full throttle in park. put it in gear and try to drive and it has no power, like it has a miss. pulled plug and it was coated black. replaced plug and put seafoam in tank. also sprayed seafoam directly into carb while running. still same problem. however, when i remove airbox it runs like normal. I'm leaning toward carb running rich,,,any thoughts?? thanks
Old 05-17-2017, 02:02 PM
Spraying Seafoam or any other carb cleaner directly into the the carb while it's running won't help clean jets,open orifices or stop problems that may be happening in the bowl. Pull the carb.
jbrj5157
08-01-2016 08:34 AM
JoshuaMichael
07-22-2016 09:58 PM
Zephead98
07-22-2016 04:27 PM
Cherokee1990
07-21-2016 11:29 AM
groovie1955
07-13-2016 10:58 AM
Quick Reply: 2012 sportsman 500HO running rich??
