No spark condition 1999 Sportsman 500 w/ ebs
#21
The throttle cable doesn’t have adjustment at the carb end? But if it did I don’t think it would help with my issue. The other black sheath around the cable vibrates up and out leaving just the cable exposed and causing the high idle. I did verify the connection for the black wire from the cdi to the kill switch, how does that provide a stop signal. The key switch won’t kill it because it is basically being used just to power the fan and headlights. Previous owner rewired that after a wreck, the headlight pod was destroyed.... all I have is a key switch zip tied to the handle bars.
#22
#23
I’ve got the wiring diagram, but the wiring is cut and spliced so much I can’t track what is missing or spliced to prevent the kill switch from working. Would there be anything wrong with putting a toggle switch in the pulse coil circuit to have a way to kill the engine? That’s how I’ve been shutting it off, just undoing that plug for the pulse coil.
#24
Rather than keep going at this thing one damaged wire after another,might be to your benefit to get a used harness complete with connectors and NO cut wires as the ad shows. Plus has a make an offer also. See if he'll take 45 bucks or so and get this thing back right..https://www.ebay.com/itm/Polaris-Spo...VaAkRP&vxp=mtr
#25
#26
All the major grounds tie into the lower coil mounting bolt.It'll run ok without the speedo plus depending on how far you want to get this thing back in shape,used pods are out there also. Just the color is the difference on these models that use the same upper and lower pod prefix number. Possible you can find a good set in your color.
Usage : 5433042-191 (Green)
Year Product Model Assembly
2000 ATV SPORTSMAN 335 HANDLEBAR and HEADLIGHT POD - A00CH33AC (4959905990B013)
2000 ATV SPORTSMAN 500 HANDLEBAR and HEADLIGHT POD - A00CH50AA (4954805480C001)
2000 ATV SPORTSMAN 500 RSE HANDLEBAR and HEADLIGHT POD - A00CH50AA (4954805480C001)
1999 ATV SPORTSMAN 500 HANDLEBAR and HEADLIGHT POD - A99CH50EB (4949114911b013)
1999 ATV WORKER 500 HANDLEBAR and HEADLIGHT POD - A99CH50EB (4949114911b013)
