I Yes my speedometer quit working my top main headlight 4x4 quit working in my
What model? If it's not showing speed or mileage,it may just be a hall effect sensor on the front strut that's out.If the speedo is dead,the yes many had the awd ground circuit go through the speedo and you would loose awd. You can bypass the speedo by jumping the brown/white wire(awd ground) to a common brown(ground) in the speedo harness or frame ground and you should be able to at least have awd. Some have repaired their speedos. Info is there if you care to at least try.http://forums.atvconnection.com/pola...ml#post3232409 KA7OEI's blog: Repair of the speedometer on a Polaris Sportsman 500 4-wheeler
