99 scrambler 400 coolant over-flow
Old May 17, 2012 | 08:10 PM
RickH's Avatar
Default 99 scrambler 400 coolant over-flow
After riding hard, the over flow cap spits out coolant through the pin hole, then the light came on. Let it cool, radiator coolant level was below the top hose and sensor. Topped off coolant, lights goes out, but after warm up it's still spiting at the over flow.
What does this tell me? Water pump?
Thanks in advance,
Rick
Old May 21, 2012 | 10:15 PM
Bing43's Avatar
Does the fan come on or work. Rad might be plugged with mud. Think if it was water pump should over heat running hard or not. Could also be head gasket only use stock gasket not cometic or any others. Just a few areas to check. Might want to put this in the polaris section to get more replys. Right know its in the ranger and rzr area.
Old May 26, 2012 | 09:24 PM
RickH's Avatar
Thanks I'll repost over there.
Fans does work, had the cap open after it cooled and watch the flow. When I rev it you can see movement, but at idle the flow is interment.
exmotocrosser
Sep 13, 2019 06:12 AM
Alex G.
Sep 11, 2017 11:38 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
