2016 Polaris Ranger 570 full size is dead
I have a 2016 Polaris Ranger 570 that I didn’t ride for awhile and the battery went dead. So I replaced the battery and now I can’t even get the dash to light up or anything to turn over. At first I thought the new battery I got was bad but I even tried using and jump box and it wouldn’t start. Any thoughts on what could be wrong would be great
First thing I'd check is the 20 amp main fuse at the fuse block. https://www.partzilla.com/catalog/po...wire-harnesses There is also a small fusible link 2202670 (#3) looks like leading to the fuse block. Hopefully it hasn't melted,but is replaceable if it has.
Even better if you look at Polaris Parts list as they list two 570xp full size.One is the full size crew also.http://parts.polarisind.com/Browse/Browse.asp
One listed for the "570,570xp full size" shows a 30 amp main fuse. Item #10 Have you checked it along with power to the fuse itself? If it's ok,problem could be further up in the fuse block or its wiring. The 15 amp circuit breaker(#11) is normally for the fan relay.That shouldn't be a factor.
GreatCanadian16
12-16-2016 11:09 AM
