Starting Problems on A Ranger
My 2019 Crew 1000 XP has developed a stating problem. After sitting it has to turn over way more than it should to start. I'm not talking about cold weather I mean not up to operating temp. Overnight sitting will usually cause this. After some research my fuel pressure is questionable. I get 52-53 psi with the key on. After starting I get the 58 psi while running that I should have with just the key on and the engine not running. I have no issues other than this. Runs fine with plenty of power, smooth idle and no missing or shuddering. Anybody have an issue like this? Thank You!
Same issue, same machine
Did you ever get this resolved?
