broken bolt
on my dads sporstman 500 he has a broken bolt. It is located on the lower tight rear a-arm in the back. I had to take the tire off to get to it and now i dont know what do do... does that bolt hole o all the way through to an opening so i can just keep threading it untill it is out or do i need an ezout???
Most of those are going to be "Blind" holes, Which means you will need to use an ez-out. You will be able to see the hole from the back if it does go all the way thru. But make sure it is fully threaded, it probably is not!
