ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   Peak RPM's of Sp600?? (https://atvconnection.com/forums/polaris/149877-peak-rpms-sp600.html)
BuddyP Apr 15, 2004 09:28 AM
5900-6000?? Just curious if I needed to adjust the throttle lever or not. Didn't know if it should be 6100 or 6200.
Polaridoo Apr 15, 2004 01:48 PM
Not sure what peak RPM should be on the 600. But keep in mind if you are not reaching peak RPM, it may not be the throttle cable. There are other issues, namely clutch tuning, that may be keeping you from reaching peak RPM. This is probably not the 'right' thing to do, but I put mine in neutral and quickly blipped the throttle to it's peak RPM (w/o load). So, in my humble opinion, you should be able to tune the engine / clutch to get close to that number. Once you know your engine is tune (carb is perfectly jetted), then you can work on dialing in the clutch to the speed/power you want it to deliver.
BuddyP Apr 15, 2004 02:23 PM
It's a new quad, have seen 6k in the past and around 5900 now. It runs fine and I don't know what R's it should be pulling. It's deffinatly not clutching, and it may be fine the way it is. It may have been overrevving when hitting 6k. That's what I'm trying to find out. Either way we're only talking 100 or so RPM.... Just was curious if anybody knew what RPM peak power was at. I can take it from there.
Let me put it this way... for you 2004/2004.5 Sp600 owners out there, what is the VDO showing for peak RPM at WOT?
bigbamaboy Apr 15, 2004 04:27 PM
I have seen my sp600 at about 6100 rpm. Idk if thats peak, but thats bout as high as i've seen it, and about as high as I really want to. Idk if that helps.
jammer42 Apr 18, 2004 09:39 PM
The SP 600 ign rev limiter is set at around 6800 rpms give or take 200 rpms.Hope this helps
© 2026 MH Sub I, LLC dba Internet Brands
