any Polaris mechanics out there? elect. problems
AWD - won't engage, no light either
speedometer - not working speedometer - no light going forward - hit override button - reverse light comes on reverse - you can go full tilt without hitting override button I've got to believe these problems are all linked but I have no idea what it would be. Dealer told me AWD is linked to speedo but I'd rather not leave it for him to "troubleshoot" for hours. |
I hate electrical problems!
Did these problems just show up from normal use? Or did something else 'strange' happen - like maybe drowning it in a puddle?
The answer will probably help where to go from here. If you have a manual, I would start looking into how to test different components. |
These problems came up after installing a new battery. I had accidentally left off a ground cable and I pull started it for a couple of days to get my work done. Once I got some time to troubleshoot, I saw the gound cable stuck behind the battery. Connected it, it started great. I don't remember if the probably was immediately after this or not.
id get a scematic and start from there sounds like a possible short or crossed wires ..
Don't know what's causing these problems but Polaris is easy to troubleshoot. Get a wiring diagram & check that all the wires are pluged into the correct spot on the connector board under the center plastic. Everything is color-coded.
Seem to remember reading something about a totaly dead battery causing problems like those.
Sorry I don't recall the details. Try calling a few shops or ask on some more forums. |
I think you cooked something. Since I am not familiar with your specific ATV, the first thing I would look for is blown fuse.
I'm betting on a blown speedometer. From the schematic, everything that i see wrong, connects to the speedometer. They're only 2 weeks backordered from Polaris. Must be a common problem.
OK unplug the speedo & see what happens. Just follow the color-code.
