Starter brushes?
Can i buy the brushes or do i have to buy a kit? the armachure looks fine,i took steelwool and cleaned it up.All i need is brushes?
Thanks Davey!!!! |
Starter brushes?
Yes, check ebay.
I bought a rebuild kit for my 2stroke starter for around 30 bucks I think. Came with brushes and bearings. -Chris |
Starter brushes?
You can get just the brushes from your dealer. But, I would recommend the Ebay rebuild kit. It has the brushes and plate as well as all the seals
Starter brushes?
the polaris brushes are available from the dealer, but heres a tip. take out ur old brushes and go to ur closest honda dealer, they will have the same set, but a third of the price, trust me.
Starter brushes?
ok guy i have a ? for u
my trail blaze lost its starter it is still drawing juse but wont the starter wont truner the moter over if i pull start it it runs fine whts f(#$in up |
Starter brushes?
Originally posted by: trailblazermudrunner ok guy i have a ? for u my trail blaze lost its starter it is still drawing juse but wont the starter wont truner the moter over if i pull start it it runs fine whts f(#$in up |
Starter brushes?
brand new bat this spring hold charge fine and yes it just click when i hit the stater! where is the starter located? are they hard to relace?
Starter brushes?
one more thing how much for the bushins?
Starter brushes?
Not sure where the starters are on the trailblazers. Probably somewhere behind or under the motor? Once you get the starter off, replacoign the brushes is very easy. The brushes are like $10 at the dealer. A rebuild kit is the best way to go. You can get those on ebay for around $35. Just pay close attention to how you take the starter apart.
Starter brushes?
i dont have a creit card so i cant buy of of ebay
