Dies when I'm stopped
Old Sep 21, 2004 | 11:33 PM
REALSORRY's Avatar
Default Dies when I'm stopped
ok, my Polaris 325 Trial Boss just recently started "thowing a fit" about a week ago. Whenever I come to a stop and let go of the throttle it dies, My guess would be that the throttle cable needs adjusted but it only does it about 15 minutes after I start riding. Can anyone help me out?
Thanks,
Jeff
Old Sep 21, 2004 | 11:40 PM
Jayblazer's Avatar
give your air mixture screw a half turn out... it worked for me..
Old Sep 21, 2004 | 11:42 PM
REALSORRY's Avatar
k thanks, anymore advice before I try this? Where is the mixture screw? which way is "out"? left or right?
Thanks
Jeff
Old Sep 21, 2004 | 11:44 PM
Bradracer18's Avatar
It sounds like something in the throttle body(area on the handle bars in the black box) remove the 3 screws and take off the cover and gasket, and see if the connection isn't being made in the box......if no connection, then your motor won't run. I hate that darn setup in that box.......has something to do with stopping throttle sticking.
Old Sep 21, 2004 | 11:46 PM
REALSORRY's Avatar
k thanks
Old Sep 23, 2004 | 12:09 AM
Farmdude's Avatar
on the right handle bar there should be cable that has rubber pieces that are black and if you spread those rubber pieces away from each other you should see like a piece that you twist and have the 4 wheeler running and twist 1 way and see if the engine is getting bigger rpms and have it in nuetral
Old Sep 23, 2004 | 12:24 AM
REALSORRY's Avatar
I did that and it idled fine but I am worried that since it is loose now it might move around and re-adjust to idle higher and higher.... Has anyone else done this? Is it safe/recomended?
Old Sep 23, 2004 | 12:35 AM
REALSORRY's Avatar
Wow thanks, I found out that other little nut to re-tighen it in its place. Thanks a lot, no more keepin on the gas and wearin down my brakes for me!
Thanks a lot,
Jeff
Jazperman
Aug 7, 2016 08:12 PM
gorylewis
27
Oct 4, 2015 05:22 PM
scram5050
Aug 19, 2015 02:19 AM
Karas3434
Aug 3, 2015 09:17 AM
raceware
Jul 30, 2015 06:59 AM
