Scrambler 500 Rear Brakes???
The rear brakes on my '00 scram are useless as well. You can stomp the pedal flat and it barely slows, let alone actually stopping the thing. Oddly enough, I still need to replace the pads every now and then. The price of the pads isn't even worth the stopping power they (barely) offer. Poor design is my guess. I just use the lever
The rear brakes were originally designed as a backup to the main system (main brake lever already puts pressure on the front and rear brakes) and has a small master cylinder that doesn't have a whole lot of stopping power compared to the old mechanical rear brakes of the 90's. Just make sure the pads are in good shape and every now and then use the rear brakes to keep the seals in the small master cylinder from getting dry and sucking air. OPT
SixSpeed5
8
08-02-2015 05:38 PM
