Shifting the E-Z shift box, also what are the gear ratios?
You have to be stopped to shift between high and low. You will know if you were moving too fast because you will here a grinding sound. I am not sure about the gear ratios. Try to see if you can find an online owners manual for the magnum. That would provide the info. on the gear ratios.
Njrider1230
07-29-2023 05:16 AM
