Xplorer 300 - 4X4 not working
I have a '98 Xplorer 300 and the 4x4 function stopped working. I also noticed that the button that enables the 4X4 no longer lights up either. Think this problem is electrical or is deeper?
I did have the gear slector loosen up on me this past winter and gave me problems shifting. I tightened thing up and it shifted good. Could the 4x4 problem be related to that?
Pulled out the multimeter and diagram and I narrowed it down to the gear selector switch. Made a test jumper to jumper out the switch then my AWD light came on. I went and took apart the gear selector and sure enough the switch was tore up. I also noticed some broke parts in the gear selector as well.
Who has some of the better prices online? Looks like the gear selector assembly runs $250
check on ebay for a complete shifter but cross referance the parts by going to http://www.partsland.com/ and make sure it is the same as the one you need. Let me know what parts are bad and I may have some of them.
