Any tips for ATV pulls?
I am going to enter my Xpress 400 in the 2 wheel drive 0-450cc class, what kind of chance do you guys think I might have. Has anyone hear pulled before? Any special tips? One of the rules is no weight can be added to the ATV. Looks like alot of fun, I guess I will find out how the Polaris 2 stroke power stacks up against the competition.
Add led shot/sand or something to the tool box!!! Ha Ha Ha. Seriously, you should do good. most of it is in the set up, Hardpacked clay track you need less tread and set your tires hard-10 psi or even higher! loose gravel or sand track, set your tires low, like even down to 1psi. Use Low range if you have it. Check or replace your belt, clutch kit helps. Adjust your rear spring as high as it will go. Are you a big guy??? If it is a loose track, get someone big to ride it!!! Push as hard as you can on the throttle!!!!!!!!!
DANO38, I see someone on a trail boss 330 at the atv pull in your pics and it has a new clutch spring in it so does the new spring help because i have a 2005 Trail boss and it pulls the front wheels off the ground off the line everytime i race someone but its stock so would a clutch kit help the torque a little or not. I would appriciate if you help me, Thanks.
BTW, Farmking i think your bike would do good in a pull so Good Luck!! Bob |
go over to the kawi forum and ask...I know there are a couple of experts there
http://forums.atvconnection.com/mess...ighlight_key=y
http://forums.atvconnection.com/mess...hreadid=386984 Hope those help you out a bit. I warn you though sled pulls are very adicting. I'm putting my machine back together right now to get it ready for some up coming pulls. With my tracks on it is one pulling machine. |
where do you pull at?
therre are a few in WI I go to. I know there are a few others in MN but I haven't found them yet
There is an atv pull in humbolt iowa this coming saturday and i am going to go down and watch, my buddy is going to take down his 500 honda and try to move the sled.[img]i/expressions/face-icon-small-happy.gif[/img]:
Hey , our club is having an ATV pull July 28th, at the Blue Earth County Fair, in Garden City. If ya feel the need to take on the competition, come on down. Atv Pull click the link and check it out!!!
I am very intrested. Guess I will have to make a phone call and get the low down on what the rules for the mod class are.
If you know of any other pulls in MN/WI please let me know. |
