help!
Old Oct 29, 2005 | 03:39 PM
BigDare's Avatar
Default help!
hey, I droped the ring that holds the connecting rod pin in. I drop it down into the crank case, is there any trick to get it out. I try one of those bendy magnets things but no luck. any Ideas
thax
Old Oct 30, 2005 | 01:37 AM
MUDATV700's Avatar
Default help!
tweezers... might work...
Old Oct 30, 2005 | 01:42 AM
sportsmanryder's Avatar
Default help!
If the motor is out I would just put fresh gas in the crank case and shake it up and flip the motor over and you should get it out, And if the motor is still in, flip the bike over. Good luck.
