I'm back
Hello all, it has been a while. I recently moved and long story short just have not had time to write. I have a couple of questions.
I was stripping down my 700EFI doing maintanence to it and found a red vacum line with a vac canister on the end of it. I can not see where this goes. Any ideas?? Also, why does it seem like more fluid came out of the front/rear differential then what I can get in? Also, I am looking for some ideas on clutch work. I have a kit in it (can not remember where I got it), it has the adjustable weights on it. I have recently taken off my Extecutioner rims and tires and went to ITP Spider Trac tires. I beleive they are 26" on the back. Any ideas on what I can do? The quad has just fallen on its face since I put these tires on. Looking for ideas. Does anyone have the link for hooking all three lights up? |
I'm back
what name did you use to post under??
I'm back
I can help you out alittle on the clutching. Sounds like you already have the heelclicer clutch kit. I would recommend getting a 800 primary and put the heelclicker clutch kit in it that will give you alot more low end. I also gain 3 mph on top speed.
I'm back
Originally posted by: sportsman2004 Hello all, it has been a while. I recently moved and long story short just have not had time to write. I have a couple of questions. I was stripping down my 700EFI doing maintanence to it and found a red vacum line with a vac canister on the end of it. I can not see where this goes. Any ideas?? Also, why does it seem like more fluid came out of the front/rear differential then what I can get in? Also, I am looking for some ideas on clutch work. I have a kit in it (can not remember where I got it), it has the adjustable weights on it. I have recently taken off my Extecutioner rims and tires and went to ITP Spider Trac tires. I beleive they are 26" on the back. Any ideas on what I can do? The quad has just fallen on its face since I put these tires on. Looking for ideas. Does anyone have the link for hooking all three lights up? And for the three light mod, just do a search, you'll get a lot of hits with the links to the packages and the DIY instructions. |
I'm back
Got mine off e-bay for $5.75 including shipping. Just search Polaris lights easy enuff to install too!
I'm back
Thanks Sportsman70003. Glad to see you still hit everyone of my posts. So, do you know what that red vacum line about 3" long with a lit vac booster on the end goes to? I have read alot about the 800 primary. It is not a heelclicker, it is BMP Supertip clutch Kit from Bikeman performance. Took me a while to remeber it.
Your front spring spacers, do you make those? I am interested.... On your 800 header install, is it worth it? I have EFI, so will this affect anything. I have already purchased the 800 snorkle, but have yet to install it. Do you have a thread for the Headlight MOD? Thanks |
I'm back
sportsman04...I could not remeber my password so i had to set up a new account. I got a new computer after I moved, so I lost mostly everything...
I'm back
Light kit on e-bay here is a link. Got mine has great instructions easy to install.
http://cgi.ebay.com/ebaymotors/Polar...88239079QQrdZ1 |
I'm back
Originally posted by: sportsman2004 Thanks Sportsman70003. Glad to see you still hit everyone of my posts. So, do you know what that red vacum line about 3" long with a lit vac booster on the end goes to? I have read alot about the 800 primary. It is not a heelclicker, it is BMP Supertip clutch Kit from Bikeman performance. Took me a while to remeber it. Your front spring spacers, do you make those? I am interested.... On your 800 header install, is it worth it? I have EFI, so will this affect anything. I have already purchased the 800 snorkle, but have yet to install it. Do you have a thread for the Headlight MOD? Thanks |
I'm back
Thanks Sportsman70003. How hard is it to install the spring spacers? What size conduit did you use?
Does anyone know where this vacum line goes? I found it lying on top of my starter when I was cleaning my quad. I can not see where it goes with out removing everything. Any ideas? Anyone? Also, do you need a needle tip for greasing up everything? I only have 2 grease zerts and they are for the ball joints ... |
| All times are GMT -5. The time now is 06:22 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
