Magnum 425 radiator hose replacement
After 11 seasons of riding, my 1995 Magnum 4X4 wore a hole through the right side radiator hose were it touches the frame. I have ordered a new hose that will be here in a couple of days. My problem is trying to figure out how to remove the old hose and then install the new one. It is easy to remove the hose end from the radiator as the hose clamp in very accessible. The hose end that connects to the engine is another story. So far it looks impossible to get to this clamp to loosen it without removing a lot of other parts. It connects to the engine very near the bottom of the frame on the right side of the machine. Does anyone have a tip/technique for doing this? I assume that many Polaris machines have the same radiator hose set up.
