Need wrecked Polaris 400 or engine
Old 01-11-2006, 12:27 AM
Trancer's Avatar
Default Need wrecked Polaris 400 or engine
Hey guys, I believe I am gonna start on my project. I need a wrecked Polaris 400 Sport or Scrambler. What I mainly need is the bottom half of the engine. I travel alot back home from Oklahoma to Texas alot
Old 01-11-2006, 12:42 AM
Webopper's Avatar
There are a couple of web sites on this thread. Also keep an eye on it to see if anyone posts any other info that might help you out.
Good luck with it...
Old 01-11-2006, 12:44 AM
Trancer's Avatar
Thanks for the link bro.
Old 01-13-2006, 04:57 PM
Scrambler40096's Avatar
What year Polaris 400 engine are you looking for? Also, which parts do you need exactly? Let me know I may have a bottom end from a 99 Sport 400 or Scrambler 400, I would have to check.
Old 01-13-2006, 05:05 PM
Trancer's Avatar
The engine that I am looking for came from a 1994 Polaris. I do believe that a 99 is the same engine, correct?
Old 01-13-2006, 06:14 PM
I have no idea, but if you find out and it is I will check and see what I have if youd like.
Old 01-13-2006, 09:05 PM
Trancer's Avatar
Do you have pictures of the engine by chance? You can hit me up on aim @ GlowstickCyberia or MSN @ jessesampson
Old 01-14-2006, 03:21 PM
badboy400's Avatar
All of the Polaris 400 motors are the same. I just had to put a 97 motor on my 03 because i cracked both cases and split the jug in half.
Old 01-14-2006, 03:24 PM
duneaholic's Avatar
The cylinders are different from a 96 and above. The previous years had a little different cylinder configuration but would still work on all years. Someone correct me if I'm wrong.
Old 01-14-2006, 06:00 PM
POLARISFREAK's Avatar
You are right Shawn, most of the pre 96 cylinders didn't have the boost ports on the side when looking in the reed cage area!
Quick Reply: Need wrecked Polaris 400 or engine
