Race Mod Spark Plug gapping?
I was wondering what a BR9ES should be gapped at for the Race Mod 400's with the stock ignition?
Thanks! |
.018
unless it's on alky I would run the B8EG or B8EGV, or even the BR8EIX. They cost more but they have a finer tip and it takes less current to fire it.
BR8ES at .018 to .020,
hotter plug make more power in those fuji motors and burn more efficient. fine tip spark plug is for very close to perfect jetting conditions,but i havn't seen any gains using them. |
I use a BR9ES because Darrell from HPD told me that is the plug I should run with the race mod.
Holly crap, you are supposed to gap your spark plugs ! Gap at .018
What plug do you run with Alcohol with all the race mods? After the $300.00+ ignition mod you can gap to .025 |
Originally posted by: Bubba297 unless it's on alky I would run the B8EG or B8EGV, or even the BR8EIX. They cost more but they have a finer tip and it takes less current to fire it. |
BUBBA knows,
Just one of those things we all learn on this forum. Put your normal spark plug connected to spark plug wire in your hand and crank over engine, feel the bite. Now try the fine wire plug and feel the bite. You can test the spark plug of your choice many times at different gaps to determine the best bite (ZAP) for the buck. |
You need to try holding the plug with the new ignition and the plug gapped at .035.Man that sucker will make you holler.[img]i/expressions/face-icon-small-shocked.gif[/img]
