Tb gets beat by a phoenix?
Old 01-29-2006, 03:36 PM
RickRitter's Avatar
Default Tb gets beat by a phoenix?
Hello guys -
Looks like we have a problem somewhere. Gurney , tech help comes with the kit , give me a ring on the phone and I will get ya going .
Rick Ritter
Old 01-29-2006, 07:38 PM
Gurney's Avatar
called rick up and gonna do a compression test on the ol TB
Old 01-29-2006, 08:13 PM
scootergptx's Avatar
Supersock
Hired Gun!
Well there ya go. Once again, Rick proves he is the man. [img]i/expressions/face-icon-small-smile.gif[/img]
Old 01-30-2006, 12:29 AM
Gurney's Avatar
not that i swing that way but i love the guy........hes better than he once was.......cant wait 2 get the results of the compression test...........rick what is the compression suposed 2 be?
  #15
Old 01-30-2006, 01:20 AM
RickRitter's Avatar
Your compression should be 120 - 125 pounds on a good tight engine .
The wear limit is down around 100 pounds .
Check the compression with ignition off , or grounded , and the throttle wide open .
If it is low put about 2 teaspoons of oil down the plug hole and recheck . If the compression improves a bunch get out the wrenches . Oil will seal the gaps and give you a fake reading . If the compression does not rise the gauge is probably shot .
  #16
Old 01-30-2006, 12:18 PM
Fastestdad's Avatar
Believe it or not the stupid taiwanese Pheonix stock runs darn close to stock TB times at the dragstrip. About 8 flat in 300 feet loose sand at our track. I thought the pheonix would be another slow taiwanese POS. Good luck gurney. Check your jetting etc. Sounds too rich or dirty airfilter. Stock dirty airfilter is a performance killer with a 250 mainjet and ritter pipe on our TB.
  #17
Old 01-30-2006, 02:59 PM
Gurney's Avatar
so let me guess if the compression is low time 2 rebuild the motor?
  #18
Old 01-30-2006, 06:17 PM
drlang's Avatar
How did this machine run before the modifications?
  #19
Old 01-30-2006, 10:03 PM
Gurney's Avatar
it ran good.............it runs better now thers just a huge flatspot right off the line
  #20
Old 01-31-2006, 01:47 PM
badazz400's Avatar
your clutch weights maybe 2 heavy for your spring
Quick Reply: Tb gets beat by a phoenix?
