05 800 efi looking for help
Old Mar 10, 2006 | 01:49 PM
Purch53's Avatar
Default 05 800 efi looking for help
Iam new to the board and iam looking at a used 05 800 efi. My dad has a06 500efi and i love the ride but my friends up here in canada say that the tiwn motor have bad water pumps and that polaris will not fixs this. But i have read alot of good thing on here can someone help me make up my mind
thanks Matt
Old Mar 10, 2006 | 03:05 PM
DANO38's Avatar
The water pump issue was really only a problem on the '02 700s. They use a mechanical type water pump seal that can occasionally weap a little in extreme cold conditions when the machine is stored. I have had a sp600 and now a sp700efi and both weaped initially when new, then stopped almost immediatly. no problems after that. Great machines when properly maintained, just like everything else. I would ride it and make up your own mind, I think you'll like it!
Old Mar 10, 2006 | 09:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
havent heard much on water pump problems.
Old Mar 10, 2006 | 09:52 PM
03Sportsman700's Avatar
The problem is when mud/dirt/sand gets sucked into the hole on top of the coolant recovery bottle. You can easily fix this with a fitting, rtv and a plastic hose. I'm going to do this with mine. I just got my 800 EFI's water pump fixed from the dealer. When the engine cools from being under water in mud/dirt, junk gets sucked through that hole in the red cap. That is the weakness. Fix it, i'm going to, and then you shouldn't have pump issues. I could see dirt in the hose under the recovery bottle after a hard ride in the mud. It only takes a few particles of sand to start wearing out the mechanical seal on the pump. Just my 2 cents.
Old Mar 10, 2006 | 10:35 PM
Purch53's Avatar
so no real big problems with 800 efi.
thanks guy/gals
matt
Old Mar 10, 2006 | 10:45 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
ive had my old 500 have dirt in the cap w/ no problems at all. but i wash mine real good after a mud ride
