Rhino lining on plastics?
Old 04-13-2006, 06:22 PM
Silversteinfan's Avatar
Default Rhino lining on plastics?
Theres a Scrambler on ebay with rhino lining on its plastics!?!?!? That caught my eye. Does any one else have it? Does it work well? It looks pretty cool!!!
Old 04-13-2006, 06:59 PM
anyone???????????
Old 04-13-2006, 08:39 PM
skrambler500's Avatar
It looks cool but I would have to say it would add a lot of weight to it.
Old 04-13-2006, 09:04 PM
so ya saw it. it does look cool but i dont think it would add to much weight. wouldnt have to worry about decals or graphics. wonder is stickers would stick and stay on it.
Old 04-13-2006, 09:07 PM
what happens when your plastic breaks how easy is it to replace
Old 04-14-2006, 10:10 AM
I dont think it would break with the lining on it, if anything it would be stronger. You just wouldnt put on a thick coat.
Old 04-16-2006, 11:37 PM
2000scrammy's Avatar
It would definitely make the plastics stronger as long as you put enough on, stickers should still stick to it but won't look very good because its not a smooth surface, and I think it would add a bit of weight overall if all of the plastics are coated, that stuff isn't exactly light-weight.
Old 04-17-2006, 12:05 AM
scrammersam's Avatar
i know that ppl have done line x which is similar to rhino lining. it would add a considerable amount of weight to the quad. if weight is not a problem then its all good. stickers wouldnt work good on the rough surface, but maybe you could sand the spot where you want the sticker. i dont know if that would work though
Old 04-17-2006, 12:41 PM
JAMIEZ71's Avatar
1st off rhino lining isn't near the thickness of Line-x. You buy rhino lining about anywhere and paint it on with a brush. 2nd If you've ever had rhino lining in the bed of your truck you wouldn't want it on the atv plastic. You can't hardly keep it clean unless you want to pressure wash it every time due to it being sort of ruff. Rhino lining would add hardly any weight to your atv if your just putting the standard thickness on there.
Old 04-17-2006, 10:50 PM
i thought that stuff wieghed a bit, like from the dealer anyways
Joe454
11-20-2020 01:19 PM
03-21-2016 06:30 PM
Quadzilla Heritage
09-25-2015 01:39 PM
XxS0ccerstarxX
09-22-2015 02:40 PM
Ricardo Covarrubias
09-17-2015 08:28 AM
Quick Reply: Rhino lining on plastics?
