Fan didn't come on...
Found my buddy stuck in the mud on my 600... washed it down and sure enough the fan won't come on. Where do I start?
WAS the engine up to operating temp when you tested, ie had sensor actually turned fan on
The pod was flashing and the overflow was spewing....
so gets back to my question in another thread re how the fan is designed to cope if it is OK to have it immersed in water/mud
would seem it would be waterproofed AND capable of being stalled without burning out if so it may have overload manual reset ?? |
Dealer says it is likely a ECM... I thought what the.... I guess if there are two thermo sensors maybe one is for the pod and one is for the fan and the fan sensor is not getting wet? If I short the fan wire should it come on?
Originally posted by: notmydayjob Dealer says it is likely a ECM... I thought what the.... I guess if there are two thermo sensors maybe one is for the pod and one is for the fan and the fan sensor is not getting wet? If I short the fan wire should it come on? |
Same happened to me a few times on polarises. When I replace the fan, I hooked it up through a toggle switch. that way I can turn it on or off depending on circumstances. I do not rely on the temp switch to turn it on.
exactly, but put switch in series with t/stat so normally it is auto but in mud etc YOU can isolate it
but that why I was asking re thermal O/L switch [normal practice on electric motors] |
| All times are GMT -5. The time now is 04:44 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
