04 400 sportsman shutting down
i have a 2004 sportsman 400 after running awhile( 1/2 hour) @ low speeds it seems to heat up and shut down the fan comes off and on during this time, no hot message is displayed after it sits for awhile it will restart anybody know whats going on[img]i/expressions/face-icon-small-disgusted.gif[/img]
do you mean the fan starts automaticly when the quad if off?
Originally posted by: jonsie i have a 2004 sportsman 400 after running awhile( 1/2 hour) @ low speeds it seems to heat up and shut down the fan comes off and on during this time, no hot message is displayed after it sits for awhile it will restart anybody know whats going on[img]i/expressions/face-icon-small-disgusted.gif[/img] A) When you run it.....does it then overheat??? How do you know this??? Does the "HOT" flash in the display??? By "shut down" do you mean the engine dies by itself??? B)Have you checked all of the obvious cooling system stuff???.....mud in the radiator fins....low coolant level.....air-bound. C) The fan cycles on/off all the time on these machine as part of normal operation. However, if you are getting the "HOT" sign flashing in the instrument display then yes it is running hot for some reason. Check the things above if you haven't already. |
the cooling fan comes on and off as normal but after a hour of or so of running the engine becomes unresponsive to throttle and stalls out it will not restart for an hour or so it will then start and run normally for awhile and do the same thing. the hot never flashes on the display
the engine dies on its own. HOT does not flash on the display. It seems to run fine for about an hour, it then becomes unresponsive to throttle and stalls out it will not restart for 1/2 to 1 hour and will then run fine again for awhile. the cooling fan comes on and off as normal during run time.
That sounds like a fuel feeding problem to me. Check all your fuel lines. Make sure there are not any kinks/obstuctions. Make sure your gas tank vent is isn't pinched.
That's my best guess. |
Originally posted by: Backinthesaddleagain That sounds like a fuel feeding problem to me. Check all your fuel lines. Make sure there are not any kinks/obstructions. Make sure your gas tank vent is isn't pinched. That's my best guess. |
