ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   Need Help..SP 500 belt won't disengage.bike keeps moving (https://atvconnection.com/forums/polaris/249522-need-help-sp-500-belt-wont-disengage-bike-keeps-moving.html)
hotdog Sep 15, 2006 05:23 PM
My 2001 Sportsman 500 won't stop moving when you want to stop and come to a idle.It was creeping a bit before but now it's like the belt is fully engaged.
I only have 1200 miles on it.I haven't been driving it much until this year..What would cause this ? Do i need to take it in to the shop or could I fix it myself?.I haven't done any work on ATV's before..thanks[img]i/expressions/face-icon-small-sad.gif[/img]
v2rider Sep 15, 2006 10:08 PM
Adjust your idle down.
stendori Sep 15, 2006 10:11 PM
either the idle is too high or maybe the one way ebs bushing is failing.
motoman67 Sep 15, 2006 10:18 PM
you need to have your drive clutch ebs shimms replaced and it would be a good idea to replace your belt also
Cormacs Sep 16, 2006 08:07 AM
I just brought mine into the shop for the exact same reason. 06 Sportsman 500 HO EFI. The shop thinks a module flash is going to fix it. Aparently a tsb covered it and that was the fix. I will let you know.
stendori Sep 16, 2006 08:15 AM
that sounds kind of funky. what is a tsb ?
hotdog Sep 16, 2006 09:14 AM
I will check the idle ..I think it was idling a bit high ..hope that's all it is .I am on vacation this week and was hoping to do some trails. If i need to take it to a local shop it would be Tuesday before he could look at it [img]i/expressions/face-icon-small-sad.gif[/img]
Is it easy to adjust the idle ?..Someone mentioned the throttle cable may be sticking too..will check this out today.
Thanks for all the help
MILKMANZ Sep 16, 2006 09:33 AM
I just had my 06 X2 in the shop for the Creep's. They needed to shim one of the motor mounts to get the clutches to align properly.
hotdog Sep 16, 2006 02:39 PM
I checked the idle it's not the problem..I will have to take it into a shop..I had put a new battery in it a while ago and the drain hose had fell off and the battery had drained some acid from the over flow onto the belt cover almost eating a hole into it..not good..[img]i/expressions/face-icon-small-sad.gif[/img]
Cormacs Sep 16, 2006 04:41 PM
TSB = Technical Service Bulletin
© 2026 MH Sub I, LLC dba Internet Brands
