ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   H/C causes belt case damage, here's the fix (https://atvconnection.com/forums/polaris/258624-h-c-causes-belt-case-damage-heres-fix.html)
Instigater Jan 29, 2007 04:07 PM
The Heel Clicker directions clearly state that the new flyweights could rub the belt case cover, so I am not mad, just sharing my experiences and MY cure for the problem. They state "push down" on the cover while tightening the cover bolts. I did this on the 800 and the 700. The clutches still rubbed on both. There is not alot of good that can be done by simply "pushing down" on the cover, while tightening. I sprayed the area with paint to see if the problem still exsisted after a harder "pushing down" It was still rubbing, and by now, the plastic was getting pretty thin in THIS area on the bottom of the case. I took off the clutches and back plate to investigate a better way. I noticed that there was enough flex in the seal between the engine and the back plate to allow me to modify the 5 holes that bolt the plate onto the transmission. By enlarging the 5 holes slightly, then "pushing down" on the back plate while tightening the 5 bolts, I was able to create about 3/8" drop with the front of the cover. This will allow more clearance between the clutches and belt case. Next, I mixed up some 2-part epoxy plastic weld and filled the grooves with the mixture! Once, repaired I put the side back together and hopefully it is fixed. I will be looking for new grooves, next time I take the cover off. With any luck, I will not find any!
onesavage Jan 29, 2007 05:52 PM
i dont have a h/c but i checked out your pics,,, mean looking mv.... i cant believe you smoked your rear winch... oh well i am sure it was a blast.............
Bill35 Jan 30, 2007 09:40 AM
Hey Instigater nice mv.I like pic #4.Brother ive been there.You cant get more stuck then that.
stendori Jan 30, 2007 10:21 AM
why is it you think that the weights are hitting the cover? are the weights that differnt from stock that they extend outside of the clutch it self?
SPORTSMAN70003 Jan 30, 2007 01:59 PM
Its the heel of the weights that rub the clutch cover. I have seen many post about this over at atvquadsquad. The heelclicker has a heel on it where stock weights don't. Thats what make the heelclicker work alot better than stock weights.
stendori Jan 30, 2007 02:33 PM
thanks for telling me sport. do they all do this on all the covers?
SPORTSMAN70003 Jan 30, 2007 05:13 PM
Most people don't have a problem. And most of the time you can push down the cover and fix the problem. It can happen on any on the sprtsmans.
Instigater Jan 30, 2007 05:44 PM
Well Sport...., you said it, LOL!!! Most people don't have this problem, but if anyone did have it, of course it would be me![img]i/expressions/face-icon-small-wink.gif[/img]
© 2026 MH Sub I, LLC dba Internet Brands
