2005 Battery Symbol & Guage Cluster Lights Flashing??
Hi, I have an 05 Sportsman 400 with about 900 miles on it and notice when I'm plowing the driveway and it idles down that the gauge cluster lights will flash on and off with a battery symbol flashing as well. But as soon as I give it some gas it goes away. The machine idles at around 1400 rpm, which I didn't think was too low and it doesn't sound like it is going to quit. Is this normal or something to be concerned about? Thanks
It sounds like you are running your battery down from using the winch. Try to keep the RPMs up as much as possible and keep your accesories off, like lights and hand and thumbwarmers if you have them. And not a bad idea to trickle charge the battery when you're done
hes 100% right. the winch is strickly ran off the battery and the bikes charging sysytem isnt designed to keep up the heavy pace of plowing w/ the winch. you either need to run the atv for long period of time to recharge or put a charger on it.
bzdok1234
30
02-23-2016 01:55 PM
KimSJoh
14
07-18-2015 07:20 PM
