Polaris AWD Hill Decent System
Got to be up front here - I don't own a Polaris although I've got significant seat time on a 500 Sportsman and 800 EFI. I'm not looking to be ragged on I just want to increase my knowledge. I have a question about how the Hill Decent feature works on the new machines? I mean, what is it designed to do and how is this accomplished? Is there a switch on the bars or anther position on shift lever, etc? How do the sensors and mechanical parts interact to do this? Thanks.
I'm not entirely sure how it works, but it's a hydraulic system in the front diff. It engages the front diff for engine braking when the throttle is closed, under 15mph, in 4x4, and in a gear (Forward low and high, and reverse) There are no other extra switches for the system, it does all the work for you. The older systems would only engage the rear wheels possibly leading to the rear wheels locking or sliding on slippery surfaces, while the new systems will engage a 4 wheels when the above conditions are met. I have had my bike on a gravel pit wall, with 2 feet of snow in 4x4 low range and let off of the throttle and it slowed me down in a very controlled manner. The same conditions in 2x4 low caused the rear tires to slide a little bit. I can see how this may cause some uneasiness to some people, but the ADC works great. Hope this helps and if anyone has anything to add, feel free, or any questions. Hopefully I can answer them.
Todd |
Does it work well enough to justify trading in an older model that does not have this new feature. I have a 2005 and let me tell you, there have been a few times my seat has had one heck of a pucker when coming down a nasty hill. I have had Polaris models for 15 years, and know how to ride them. I just wonder if the new system would be worth it.
Sammy, Not saying it doesn't work as you suggest because I don't know, but if it does works as you say, then would it not also work going UP hills as well? And if that's true, why are they calling it a Hill Decent System?
not to sound stupid, but using the brakes on any machine would be the best controll. most bikes dont even have this kind of system and they all seem to get along fine. personally i like my ebs more on straight aways just to save on the brake pads more then i do for hill desending. no matter what you have for engine brakage, once you loose wheel tractionyour done for a skidding ride. lol.
No it only works when you are OFF the throttle. So going up hills on the throttle it's just called 4x4. As far as trading up to get ADC, I don't know if it would be worth it as Sten said, A lot of bikes don't have it and they work fine.
Sammy, Good point about the throttle. It sounds as though the Hill Decent is an electrical override to the existing AWD system so when certain conditions are met (off-throttle, AWD, etc), the front and rear axles are engaged like most other mfgr's manually linked 4x4 systems. Would that be a fair assessment? How much extra is this system over a non-equipped machine?
Exactly how it works. But it's hydraulic and electric. The old style has a "Sprag" clutch in the hubs that is a one-way clutch allowing it to freewheel if the fronts spin faster then the rears that would not allow 4x4 when the EBS is active. The new ADC locks the front to the rear when the conditions are met
i read on atv quadsquad (under a sticky "featured topics") about how to engage your awd by spinning the rear tires in reverse with the overide button depressed, this activates the awd. i gave it a try at the top of a hill and then shifted into low and i creaped down the hill with my ebs controlling both front and rear tires.
Originally posted by: cableguy657 i read on atv quadsquad (under a sticky "featured topics") about how to engage your awd by spinning the rear tires in reverse with the overide button depressed, this activates the awd. i gave it a try at the top of a hill and then shifted into low and i creaped down the hill with my ebs controlling both front and rear tires. |
