Light Mod Kit Trouble
Lose the diode and wire in a relay. The diode works as a current blocker one way, and allows flow the other and doing so it uses about 0.7 volts in the process. That power loss is the heat you are feeling. And if the diode is poor quality it will burn out in a short time. A relay should last a LOT lonfer and be easier on your headlight switch
Thanks! It's rsimonoff@snet.net.....I really appreciate it...also, enjoyed your photo gallery
speedbuff
13
11-11-2020 10:16 AM
Steeldon
09-09-2015 09:38 AM
