ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   conversion's (https://atvconnection.com/forums/polaris/278005-conversions.html)
trybaj17 Nov 24, 2007 11:25 PM
conversion's
I have a 2002 magnum 325. I was wondering if it is possible to convert from a swing arm to IRS like on a 2002 sportman? They are the same chassie right?? Is there a kit to split the breaks so that the handlebar break works the front and the foot break does the back, or add another handle bar lever to do the back? What is a good primary and secondary spring to get for the PVT clutch because i put bigger tires on?
SCRAMMYTODD Nov 24, 2007 11:48 PM
conversion's
If you want to go to IRS you would have to buy a transmission and work your way back. I don't think the rear of the frames are the same. I think there is a split brake system somewhere, maybe do a search. And for the sprins, someone will pipe up sooner or later. Hope this helps
© 2026 MH Sub I, LLC dba Internet Brands
