ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   Won't idle (https://atvconnection.com/forums/polaris/281102-wont-idle.html)
resqdoc Jan 13, 2008 02:23 PM
Won't idle
I have a 2004.5 carburated 700 with K&N filter, Pure Polaris pipe. Jetted at purchase for my altitude (7000+ ft). Upgraded to 800 primary clutch and Team Roller secondary.The only service has been regular fluid changes. Recently I replaced the plugs and fuel filter (near fuel pump).
If I don't touch the throttle it <u>starts and idles fine </u>at half choke. (Cold climate, temps in teens). Once I touch the throttle it won't idle. I can ride for hours and it won't idle once the throttle has been engaged. It seems like it's going to idle fine as I let off the throttle but once I let out the last 1/16th inch (it's already down to idle speed) it dies as if a kill switch has been tripped. This applies to any choke setting. The choke does not seem to be sticking. It does seem to run too rich (by smell). I disengage the choke ASAP as it warms up.
When I cleaned the air filter there was oil in the air cleaner housing (1/4" deep puddle).
Where to go from here?
badmoose Jan 13, 2008 04:37 PM
Won't idle
could the etc not be adjusted correctly? If your throttle does not have the correct free play it could do as you have described
resqdoc Jan 13, 2008 04:46 PM
Won't idle
That looks to be it. I adjusted the cable and it cleared right up.
What is the ETC?
stendori Jan 13, 2008 05:42 PM
Won't idle
eletronic throttle control. its a safety devise that stops the enigne if the throttle is stuck wide open. there should be about 1/8" free play in the throttle.
resqdoc Jan 13, 2008 06:02 PM
Won't idle
Thanks. Mine seemed to have less than that. I adjusted it, the problem went away and it's back to running great. I appreciate the input. Heading out to play in the snow! Wohooo
badmoose Jan 13, 2008 08:29 PM
Won't idle
glad you got it fixed up, that could get aggravating ever time you let off the gas it dies.
resqdoc Jan 13, 2008 09:39 PM
Won't idle
Man, you're not kidding. Especially when plowing snow. I let of the gas about every 5 seconds....
© 2026 MH Sub I, LLC dba Internet Brands
