ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   WHAT ARE THE DIFFERENCES BETWEEN 00' & 01' XPLORER 400'S!! (https://atvconnection.com/forums/polaris/28189-what-differences-between-00-01-xplorer-400s.html)
TDBRPH Jan 13, 2001 06:30 AM
According to the polaris website the 01 is a couple hundred $ cheaper no pod headlight and no speedo/odo/hourmeter. Is this correct and are there any other changes.
Thanks,
Triston
MEANGREENMACHINE Jan 13, 2001 12:32 PM
I believe that is correct. It's actually about 500 dollars cheaper than the 2000. I don't think that it looks right without the headlight pod. I would rather have the 2000. They should have never changed it.
TDBRPH Jan 13, 2001 05:39 PM
What makes it $500 cheaper ?
Thanks,
Triston
Rammer Jan 14, 2001 08:05 AM
2001's also have stainless steel braided brake lines, hardened rotors, sintered metal brake pads,improved brake lever/master cylinder, different air box and filter, 200 main jet instead of a 210, lower steering post bearing instead of a bushing,and improved steering geometry for lighter steering.
© 2026 MH Sub I, LLC dba Internet Brands
