Correct pre- mix ratio using Polaris two stroke oil?
Hello-
I just bought a 2000 Xplorer 400 4x4.
The injector is blocked off.
The previous owner ran BEAN OIL in the gas at a 32 to 1 ratio.
What should I mix the gas with and at what ratio to make this run right and live a long time?
It has 800 miles on it now.
I already bought the Polaris oil to mix and has no ratio on the bottle.
Any advice?
Any advice?
I would stick with the polaris oil my buddy ran a couple tanks of that bean oil through his blaster once and fouled a few plugs. I gave him a tank of my gas w/ the Po oil and it never fouled a plug he switched after that I still have the bean oil in my shed.
Thanks alot!
That gives me room. Now, I understand the basic formula and I wonder what the range is on a tank of gas so I can start planning how many gallons to bring to "the farm" on weekends.
Is polaris fuel additive the best for bearings, etc.?
