ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   Razr2's on Scrambler (https://atvconnection.com/forums/polaris/289896-razr2s-scrambler.html)
MNScrambler May 14, 2008 05:36 PM
What would everyone recomend for tire pressure running Razr2's on my Scrambler?
embler May 14, 2008 08:34 PM
5 to 6 psi depending on the terrain.
ftwflh May 14, 2008 11:14 PM
4 front 3.5 rear
user493 May 15, 2008 07:52 AM
Whatever it says on the quad for stock tires. If it says 4 PSI Front and 3 PSI Rear, I would run that pressure.
MNScrambler May 15, 2008 10:42 AM
I wasn't sure if I should just stick with the stock recomendations or not since the stock tires are just 2 ply and the Razr2's are 6 ply. Would this effect what pressure I should run?
user493 May 15, 2008 12:33 PM
I would still go with the recommended for stock pressure and see how it rides first. The 6 ply should be a lot stiffer so MAYBE you can run with less pressure. I think any more pressure than recommended would make it too hard. I would also only change it in 1/2 PSI increments.
© 2026 MH Sub I, LLC dba Internet Brands
