Fuse Block Description 2008 Polaris 800
Can someone tell me what the fuses are for in the front carrier rack? A 6,10, and 2 20amp fuses. The 2 20amp fuses all of a sudden keep blowing and the diagnostic codes I am receiving are a 25 and 54. Thanks for any insight.
you want to know what the codes are, or what the fuses go to? give me a few minutes.
5 amp+ speedo 15 amp=efi 20 amp=chassie power 20 amp=accesory power 15amp circuit breaker is for the fan. |
code 25= transmission input- invaid gear
code 54=engine lamp temp-open load -short cicuit to ground -short ciccuit to battery this is what the manual says. |
Chaffed wire somewhere maybe?
Fuse Block Description 2008 Polaris 800"></title><script src=
Thanks everyone for the input, sorry its taken so long. According to Stendori, my problem is coming from one of the 20 amp fuses. I have a bike just like High Octane, I have also had a problem with the fan fuse blowing. For instance, if I had just stopped the bike(turned it off) then oh we are going somewhere else & turn it right back on with the fan still running it blows. It doesn't seem as though it should do that?? Any how I really appreciate the help!
check to see if the fan is turning freely and doesnt turn over bu hand hard(w/ the bike off or course). check w/ the bike running and reverd up to see how many volts its putting out and check the wires to see if its chaffed bare metal and shorting out.
