250 trail blazer bogging problem
The machine seems to run fine but when you drive it , it acts as if it runs out of fuel and gets more and runs out and so on!!
- changed both fuel and oil filters
- took carb off and blew out air jet and main jet
- air cleaner is good K&N filter
everything seems to be clean so I'm lost don't know what else to try??
if you have any ideas it would be greatly appreciated thanks!!
check the spark plug to see what it looks like. running lean/rich. did you check the float when you had the carb off to make sure its working correctly and its set right?
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
