Carb Issue
Old Sep 1, 2008 | 09:57 PM
tbush's Avatar
Default Carb Issue
Just purchased a 2000 Trail Blazer 250. It is bogging down when I throttle past 1/3. When I throttle to about 1/3, I can open the choke and open the throttle to nearly WOT without bogging down. Any suggestions?
I have replaced filters, sparkplug (gapped correctly), cleaned the carb, etc.
Adjusting the two adjustment screws on the carb have not helped.
Thanks,
Troy
Old Sep 1, 2008 | 10:10 PM
Default Carb Issue
IF RUNS GOOD WITH CHOKE ON then almost certain carb jet or jets still stopped up OR wrong JETTING?. Did you replace needle and seat,check float height? Make sure main jet and small pilot jet screwed in body of carb clean and open. Also check that vent tubes open. Also is compression good (100 psi or more) AIR/fuel screw should be about 1 1/2- 2 turns out. Simple engine,should be able to narrow down. Good luck
Old Sep 1, 2008 | 10:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Carb Issue
main jet is plugged or high speed circuit for sure i would guess.
Old Sep 1, 2008 | 10:13 PM
tbush's Avatar
Default Carb Issue
Thanks for the replies. I will follow through on these.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
